Discuss swapping halogens for LED / some dimmer ... advice needed please in the UK Electrical Forum area at ElectriciansForums.net
W
wifiuk
I have some of these lights
And some of these
And I want to replace them with Some MR11 and MR16 LED's .
Some are on a dimmable switch and I have been reading about the type of switch and LED bulbs . About trailing edge etc. And buying dimmable LEDs to use on normal dimmer switches.
Now I saw this in a cupboard of mine when I moved into the house not sure if they are fitted or spare or where they would be if they were fitted.
Some advice needed I think ...
Can LEDs be used as replacements to halogen spot lights, some on dimmers some on normal switches?
I am a n00b when it comes to lighting etc....
ok so had a nose round in the loft and saw this
each of the lights is setup the same way ...
im guessing the blue things are called drivers ... from what i have been reading
aurora au-sm60tl
if this is of any help ..
you currently have 12v halogen spotlights, you need to alter exhistiing wiring to suit LED lamps.
also your dimmer may not work with LED dimmable lamps cause the dimmer will have a minimum load rating.
i cant afford to get all my rooms rewired :( but i want to put low watt energy saving bulbs in each room... i have seen LED equivalents... but have only 5w rating and that blue things min of 20W :( cant i replace them ?
its easy for us!!! you need to post a picture of these 5w lamps you talk about as they might be 240v GU10 type
TopCat has posted a lamp above the pins on the lamp are different to the 12v lamps you have.(thanks TC)
so something like this or what ever will work ...
[h=2]INFORMATION[/h]
Lumens120lmBeam Angle120
Power Consumption1.8wCE & RoHS CertifiedYes
Input Power12VSize35mmx37mm
WattageNoEquivalent To9w
Average Life in Hrs50000Voltage12v
BaseMR11Dimmable (Option)No
Bulb TypeLEDColourCool and Warm
im happy to get the dimmer switch removed and just have off and on ...... still dont know if it'll work. Theres about 4 lamps in each room and each one has the same setup on it
My advice, to keep things simple and cost effective would be to replace the MR16 lamps with LED MR16 and remove the dimmer switch and replace with standard on/off switch. You can get MR16 lamps that run straight of 12v electronic 12v transformers, I get them from a company and they work well, nice and bright(not sure if I can name the company here though)!!!!
Reply to swapping halogens for LED / some dimmer ... advice needed please in the UK Electrical Forum area at ElectriciansForums.net
I fitted a dimmer switch by daisy chaining the dimmer switch to a normal plug. The challenge is the light flickers at random intervals. If I take...
I really need help with this puzzler. First - I am moderately 'skilled' in day-to-day basic wiring. My puzzle: I am trying to replace a...
Hi all, Great forum with lots of advice read and greatly received over the years! I have a question here that I am hopeful somebody here can...
Hi we are replacing light fittings in our home. Im confident with the fitting aspect, but have run into doubt in making the right choice of...
Hi :) I'm currently renovating my outbuilding. My electrician has fitted 10 conduit LEDs (that support both leading and trailing edge) and x4...
