just a quick question I’ve searched online but want to be sure before deciding what to do.
I am putting in a supply for x5 110v commando sockets in a workshop.
The commando sockets each have a internal 16amp double pole MCB inside the socket.
I’ve wired from the DB a 32amp 10mm2 supply to a centre tapped transformer as per drawing.
From here I was unsure how to wire out to the x5 commandos.
So I ran a cable from the transformer in to a small 6 way DB and and fed the commando sockets from there the issue I have is that I’ve used x5 16amp single pole MCBs, then thought that they might need to be double pole MCB’s.
Would I need to change the small Db for a larger one and feed the commandos with x5 double pole MCBs?
thank you for your time and have a great day ??
