Discuss 2 rcbo tripping. 2 rcbo tripping in the UK Electrical Forum area at ElectriciansForums.net
casperLennon
Hi. Today I turned a rcbo on and it tripped straight away and took another one with it.
Any help is appreciated.
I didn’t have time to look at anything so just wondering what are peoples initial thoughts
It is not unknown for "instant" RCD to trip on surges so switching on to a fault could do it, big dV/dt on the supply from the high fault current and so high peak leakage from C * dV/dt
Other common thing is stray fingers accidentally hitting an adjacent test button, more so if you jump with an on-fault BANG! when closing something!
Reply to 2 rcbo tripping. 2 rcbo tripping in the UK Electrical Forum area at ElectriciansForums.net
Folks. I need to install a defib unit outside on a wall. Does this require an RCBO or not, just wondering as the unit has a small heater within...
I’m probably going to look stupid here, but it will be worth it if I get the answer 😆, as I can’t fathom it out. I’ve never really thought of it...
I have a ring cct (2.5mm ) in my cabin which is protected by a 20amp RCBO. This has been in existence for over 3 years with no issues. I recently...
Ring main was on a c40 rcbo so I tested the circuit everything was fine and dropped down onto a b32, It’s quite a long circuit but only serves...
Hi all, Wondering if you could offer some advice please. I carried out a small outdoor lighting project today at a commercial property. 4 lights...
