Discuss 2391 - 2394/5? in the UK Electrical Forum area at ElectriciansForums.net
B
BOROROBBO
hi all,
I'm looking at getting the equivalent to the 2391. would that be the 2394 or 2395 or both?
The other question is where can i sit these exams in the north east? All the ones I've rang have said they only do it down south now because there wasn't enough people wanting to do it up here.
any help is much appreciated as always
cheers
As noted elsewhere (search 2391), together the 2394 & 5 are regarded as a replacement for the 2391. You can sit them in any order but probably makes sense to do the 2394 (Initial verification) first. There is a fair amount of crossover between the two as you might imagine.
As timbobelfast has said, the final sittting of the 2391 is December this year and unless you have already registered to sit it, that boat has sailed.
Sorry, can't help you with colleges in your area - suggest you just try each one individually.
Regards
I know it's a hell of a trek but have you tried South Tyneside College? They're always pretty busy with electrical courses
2395 is seen as the more relevant replacement for the 2391, but i would try do both. I can offer both as one course in Bradford, but that is one hell of a trek, especially as you would have to trek down at least 3 more times after the course, to complete exams etc.
Cheers............Howard
What's happens if you have your 2391
2391 quals are still totally valid. S&G change/renumber quals quite a lot. Why - well you'd need to ask them, but some suggest that it was the high failure rate (around 60%) on the 2391 which has led to the change. Quite simply, from this year the I&T qual is the 2394/5.
Reply to 2391 - 2394/5? in the UK Electrical Forum area at ElectriciansForums.net
Hi there, firstly wishing you all good health and happiness 🙂 Just a few questions if you all don’t mind answering for me please.. I’ve just...
OLDBOY
O
So I just started out recently and I’m struggling with what to price myself at. It’s worth noting I live in the east London area and I’m looking...
Hi all, first post so go easy! This is for people who are looking for more info on the course and exams and is from my experience of doing the...
Hi all, I'm planning on adding some lighting to an old stone shed, there's currently a 2.5mm² SWA supply to the shed only supplying one IP rated...
Hi all, I’ve not long started out on my own, and so because of this I try to keep my quotes down to generate business to start, but I seem to...
5K
