J
jumpin jax
I currently have a problem with a 72 kw storage heater which is blowing 100 amp BS88 about one every 4 days, it is now on its third. The fuse is always on the same phase. I have measured the line currents as L1 33A L2 99A L3 105A Neutral 69A, line/line voltage under load measured approx 405V between the 3. Some of the elements had failed before I got involved with the heater hence the 33A on L1 and 69 on neutral. The elements appear to be wired in delta. This heater has ran for approx 25 years and was installed with a MEM 100A exel switch fuse with 100A BS88( a bit close would have been better with 125A). The Heater works on economy 7 with boost overide but this is never used except when testing. The manager tried to get a manual with a wiring diagram but with no luck as only one firm deals with these now and is very closed shop in the help department unless you want to pay them to travel 200 miles which is no good on a call out. The fuses that have blown look overheated and not just ruptured instantly.
At this building we had a fuse blow on one phase on the pole transformer in December and was wondering wether there is a voltage surge at night time causing overload of the fuse. The Coke machine went wrong this weekend and the engineer told the manager it was probably due to a surge. How easy is it to get UKPN to data log the incoming supply? Or do you guys have any other ideas? Thanks
