Discuss Accessability of JB's ? in the Industrial Electricians' Talk area at ElectriciansForums.net
I
ian t
During my part P evaluation by niciec examiner, I was showing him my use of JB's. First one under the plinths in the kitchen, and second one under upstairs floor boards. (Both were marked on my installation drawings) I was informed that they were not classed as accessable? Why? I would appreciate your wisdom on the subject. Thanks in advance
Ian T
Ian T
Hi Ian t
Welcome to the forum ,as this is your first post ,ill be gentle ,im glad the niceic inspector didnt pass your work ,im not sure what code it could be failed on ,but to have work inspected that includes a joint box under a kithen unit is a bit silly,
how rough can you get:confused:;)
My wisdom on the subject would be not to use them :)
Thanks Rumrunner, I appreciate the advice. I still do not see why using a JB under an easily removable plinth, secured off the deck, and easily accessed for testing, fault finding etc is unacceptable? Am I missing something in the regs? A spur from the back of a socket is not always the ideal solution. Are the use of JB's a 'no no'?
Ian T
A bit of a contentious issue this, What is 'accessible' and how far does it go.
I dont see anything wrong with joint boxes, providing the joint is properly done, others disagree, but that is why its called a forum, to express diffrences of opinion.
Obviously its better if there arnt any J.B.'s, but if they were so bad,and so against the regs, why are they still on sale ?
I agree with rum on this one JB`S are for diy enthusiasts who dont know any better,what possesed you to show them to mr NIC?did you think he was going to say well done?You was asking for trouble mate,did he fail you or say you got to put it right and have a revisit at ÂŁ300 ,OUCH.
I consider a JB as ok to use but showing them to the NIC inspector is sheer suicide. He wouldn't have had a clue they were there so why open yourself up to be shot down by him.
Difference of opinion regarding use of JB's, but a big 'no no' showing them to inspector. Point taken, but unfortunately, hiding something from an inspection doesn't bode well with me, but then I must be a 'DIY enthusiast' who doesn't know any better.
Yes, not a thing i would show, but as long as it is accessible, fixed and all cables entering are clipped right up to the point of entry then i dont see a problem.
I still use the small ones for downlights.
Dammit, i must be a diyer too.
All sorted. spoke to Nic inspector today. The outcome in brief... JB's ok for addition to circuit, but not 'favoured' with a new circuit. It makes sence when explained. However he did say "Anyone who openly says the JB is for the DIY enthusiasts, is a pompus idiot." and do you know what?... I agree.
Thanks again folks.
Ian T
I have been told i missed my calling by not joining the diplomatic service:eek: but where i come from mate you call a spade a spade ;) not allways liked for it but hey thats life:p
Reply to Accessability of JB's ? in the Industrial Electricians' Talk area at ElectriciansForums.net
Hi everyone. Hopefully someone can help with a little mystery i had today. The issue is fixed but I want to understand what was going on to help...
I have been asked to change cu from old fuse board which has 6 fuses. Only 4 fuses are used. The first fuse feeds cooker circuit. This is not used...
  • Locked
Good evening everybody. I have a cooker feed from the CU that is then split under the floor above the kitchen to separate outlets for the hob &...
Hi guys, I've gotten AI to write up a terms and conditions for my company and then went through it with AI and tweaked it to make it sound a...
Well....wiring in a 1750s thatched cottage attic, not wiring made from thatch 🤪 One we have been letting for over 20 years (as well as enjoying...
4K
