- Reaction score
- 4,241
Post in thread 'Joining existing cooker cable' Joining existing cooker cable - https://www.electriciansforums.net/threads/joining-existing-cooker-cable.171419/post-1501961
Discuss Correct way to joint 3 x 30 Amp cables, 30A JB not big enough in the UK Electrical Forum area at ElectriciansForums.net
One of those cables is likely to be larger than 6.0.Post in thread 'Joining existing cooker cable' Joining existing cooker cable - https://www.electriciansforums.net/threads/joining-existing-cooker-cable.171419/post-1501961
Yes, there are a few 60A rated boxes with cable clamps that should take those cables, but as you say they are not MF so would need to be kept in an accessible location.A Knightsbridge 60amp junction boxes are much better than what you have but are not maintenance free/screwless terminals. I would use them in a loft when extending electric showers.
That's two cables, this is three.Post in thread 'Joining existing cooker cable' Joining existing cooker cable - https://www.electriciansforums.net/threads/joining-existing-cooker-cable.171419/post-1501961
Much as I agree with you I have just had a professional do a part P rewire and this is one of the issues I am left with.It might be better to look at extending the supply cable using the correct size crimps and heat-shrink, and then putting any junction in an accessible location, or better still having it join at points such as cooker switches, etc.
However that would need proper crimp tools, etc, so really you would be better to get a professional in to do it.
No there are three cables already, I am not adding anything, just trying to improve an existing joint that I feel is inadequate.So you are adding a third cable.
It seems your answer wins Aaron as there are no MF products that fit this cable and will certainly be streets ahead of what's there at the moment, thankyou.A Knightsbridge 60amp junction boxes are much better than what you have but are not maintenance free/screwless terminals. I would use them in a loft when extending electric showers.
It does not win it is not suitable.It seems your answer wins Aaron as there are no MF products that fit this cable and will certainly be streets ahead of what's there at the moment, thankyou.
This has to be the only real optionRewire it back to the CU in one continuous length, and use a duel plate to connect up your hob and oven.
If you can't rewire it then ditch the laminate and use a floor covering that allows the junction box to be accessable when making considerations safety comes first and nothing should get in it's wayUnfortunately domestic considerations get in the way of such an ideal solution.
And how did you assess this person to be a professional. From your past threads the theme seems to be to keep the costs as low as possible and cut corners to suit yourself so was this a cheap rewire and you only got what you wanted to pay for or did you get proper advice from a qualified professional and................ignore it or more likelydid the professional you hired quit the job while he was ahead because of you demandsMuch as I agree with you I have just had a professional do a part P rewire and this is one of the issues I am left with.
What is a part P rewire? Is it a REWIRE where they use Red and Black old coloured cable....You have not had a rewireMuch as I agree with you I have just had a professional do a part P rewire and this is one of the issues I am left with.
I looked into this when I had to extend some cables, and Wago don't seem to do an MF enclosure suitable for the 221-612/3 range, which seems like a gap in the market.These might be of help:
Edit: Oddly TLC say 1-1.5mm cable but the data sheet says nothing - needs more investigation.
The normal (original) Wagobox is fine for the 773-173 as MF, though 3 cables would be right on the limit of what it can take physically. Also only rated for 32A.
You keep on asking professionals for their opinion and when it is not what you want to hear you post this, REALLY!! grow up and get a lifeI don't know why I bother with this site. It seems to have a fairly large contingent of conceited individuals intent on handing out insults that completely destroy the efforts of the few nice helpful people. Please delete my membership.
Reply to Correct way to joint 3 x 30 Amp cables, 30A JB not big enough in the UK Electrical Forum area at ElectriciansForums.net
