M
Mayotuna
Hi
New to LEDs, curious to how you’d go about getting LEDs on a strip to flash one after the other.
Small strip, 3-5 LEDs.
Ideally with a minimal amount of components. (Ive got a small area to work with)
You'll need LED tape designed for the purpose, you can't use a standard LED tape for this.
I know tbe product as 'pixel tape' each LED has a small chip connected to it which receives data and controls the LED according to that data.
You'll also need a suitable power supply and a controller to output the data signal, this can be done by an arduino for example or a proprietary controller.
  • Agree
Reactions: Mayotuna
One of our sponsors might help you with this
instyleled
  • Agree
Reactions: Mayotuna
Thanks for the advice Dave, looking into how small I can get the controller now.
Any controller you might suggest?
Seems like a fairly basic animation, do we really need a controller?
There might be a product out there which handles the sequence generation within the tape but I'm not aware of it.
If using pixel tape then yes you need a controller, as something has to tell each LED when to switch on and off.
Email
Time zone
Last seen
Animating LED Strip
Lighting Forum
Thread Tags
Mayotuna,
davesparks,
