Discuss Armoured cable size 1.5 in the UK Electrical Forum area at ElectriciansForums.net
Cus that was all the Person that installed it had in his Van at the time probably, or he mistook it for 2.5mm2Hello all ,
In the garden there is 1.5 3 core armoured cable running from the exterior wall to an outside socket , the power is from a socket inside the house (on the interior of the same wall) I know the sockets are wired in 2.5 but why is the armoured 1.5 ? Thanks
Change of cable size should in all honesty be fused down via a FCU in my opinion.So my water feature should be okay plugged into it ? It’s a double socket not a single
it will be fine. as pete says, really should be fused down, but as long as you don'tplug in any large loads. no problem.So my water feature should be okay plugged into it ? It’s a double socket not a single
Reply to Armoured cable size 1.5 in the UK Electrical Forum area at ElectriciansForums.net
