B
brydon78
Hi all new to forum, so be gentle
When I switch the bathroom light on, the light is fine but the fan extractor does not work
sometimes the bulb intermittantly will be dim (GU9 BULB ) this is the only time the extractor will come on.
-checked power from SL & L on extractor all good & zero volts when you turn off isolator.
any possible causes for intermittant fault?
Thank you.
Thank you.
