Search the forum,
Discuss Bell wire in the DIY Electrical Advice area at ElectriciansForums.net
Bulldog
I went to my son in laws house to put a transformer on some bell wiring he had done recently. The bell wire ran from the the door bell to the place that I would place the transformer ( distance about 12 feet) I tested the wire and there was no continuity(used a car continuity test or with light) I even hooked up a temp 18 vac transformer but the reading at the door bell was .321 vac- they used regular 18 gauge bell wire( 3 wires in a sleeve) can anyone explain why this is so I’m completely stumped everything is sheet rocked so I can’t see the bell wire how it is run thank you
TL;DR
Bell wire
No continuity means broken cable.
It’s a pain but it will have to be replaced.
Only other possibilities are incorrect measuring techniques or a faulty meter.
You say the wire is run from the doorbell to the transformer position.
Is there a push button in the circuit?
Reply to Bell wire in the DIY Electrical Advice area at ElectriciansForums.net
I am planning to replace battery powered door bell with one of these mains powered sets...
Hi all, so I bought a Ring wired ring door bell on Amazon prime day, £45 with free echo dot! Anyway fitted as per instructions and it works...
4K
Hi! I’d like to install a pedestal-mounted (230 V, 30 A max - programmable) EV charger close to my driveway, which ends about 12 feet away from...
4K
Hey all, looking for a bit of industrial electrical advice, I'm kind of stuck between a rock and a hard place at the moment, the company I work...
4K
OK, I'm still as green as a baby's nappy with all of this. I decided to change career and took a part-time night course (More on this later if...
16K
