dtec dave
Evening..I just wanted a bit of advice on the procedure to follow with regards to consumer unit changes, advice to customers and how to fill in an EIC. I have recently changed a consumer unit and I informed the customer beforehand that there may be faults on the system when the cables are checked. Low and behold when I checked the insulation resistance there was a cable down on a circuit. I have told the customer about it and told them I can investigate further, they then told me that they couldn't afford me doing remedial work and they would sort it out at a later date. How do I then fill out the EIC knowing there is a fault on the installation?
