Discuss Bollard Lights & Ants in the UK Electrical Forum area at ElectriciansForums.net
Got called out by a customer I had installed some bollard lights (Aluminium Bollard Black 750mm - 100w ES - https://www.tlc-direct.co.uk/Products/GLAB3.html) for a few years back to say they were getting random RCD trips, mainly at night when the outside lights were on.
Bollards were installed in what I would consider a fairly typical fashion, bolted to concrete pad, SWA loop in and out into a Y conduit box, with gasket & lid, wagos inside, TRS out to the lamp holder.
Started looking at the problem, IR tested the loop the bollards are on and it's around 0.08 meg. It seems that some of the bollards were completely full of soil and ants, to the point that some of the Y boxes were damp inside and some of the ES lamp holders were also full of soil. Cleaned them out, replaced the lamp holders, remade the connections and all is good again.
Any suggestions for how to keep the ants out of these things? I was considering a load of silicon around the inside of the base, but I'd rather keep that clear so that any water that does get in can drain. Other than filling the bottom of them with ant powder, I'm guessing some of you have come across something similar?
I've come across exactly that. Bollards half filled with fine soil as the ants moved it up into the cavity. Poor IR results down the whole circuit that was narrowed down to the lamp holders. The ants had only affected 2 bollards out of 10 but all lamp holders needed replacing, so maybe the two issues are not exclusively related.
As for an ant proof solution, no real clue as the owner had all the bollards taken out after they had been repaired.
I replaced all of the lamp holders out of course too, with heatshrink covering the terminals in the hope that it might help. My concern is that the ants will be back along with the issues they bring.
I have suggested an annual inspection and clean out of them, which may help, but keeping the ants out would be best!
You could fill the terminal box with a waterproof putty then put lid on, not sure what could be done to protect the ES lamp holder, I suppose that would require the bollard having a suitable ant proof enclosure.
Thanks, I have shoved some waterproof putty around the cable entry points in the hope that will keep the junction box dry if it does get full of soil again and have suggested annual maintenance with a dusting of ant powder if / when they appear.
Ants have got to be better than slugs...
Reply to Bollard Lights & Ants in the UK Electrical Forum area at ElectriciansForums.net
Hi everyone. Hopefully someone can help with a little mystery i had today. The issue is fixed but I want to understand what was going on to help...
For various reasons out of my control, we have wound up in a situation where we have 1.5mm SWA cables buried in these pillars and exiting out of...
7K
Hey, I lifted a few sockets from a wall so I could paint without having to cut in around them. I haven’t lifted any light switches yet. When...
I commissioned an EICR to be done on a property that is in Wales as this is now a requirement in order to let on any new tenancies after 1st...
