Don't follow youHow could they be harmonized when they're coloured as per size. You'd have umpteen colours per size.....what a mix up.
Got it - thanks for clarification!He's saying to have them coloured to match the cable colour they're fitted to AND colour coded to conductor size would result in far too many needed to be practical.
Seems a very valid point. I mean Shirley if you just strip the right amount of conductor insulation in the first place there's no need for insulated ferrules. Where do you buy your uninsulated ones?I can solve that problem, use only uninsulated ferrules.
RS or get wholesaler to get them, they are really useful for small terminals and for 13A plugs if I'm in a good mood.Seems a very valid point. I mean Shirley if you just strip the right amount of conductor insulation in the first place there's no need for insulated ferrules. Where do you buy your uninsulated ones?
That's what they are called by the manufacturers.Not sure uninsulated and insulated are the correct terms for boot lace ferrules?
The little coloured plastic part is hardly insulation.
Saying that, I prefer the insulated ferrules as the plastic part allows for easier insertion of the wire.
Yes, it is.That's what they are called by the manufacturers.
