Discuss Can use wiring meant for switch for power socket? in the UK Electrical Forum area at ElectriciansForums.net
Status
Not open for further replies.
VeeCee
There are 2 unused wiring I would like to make use to fix-up power sockets. One box has Live, Neutral and Earth. The other box has only brown wires. One of the box is labelled S3. I presume its for lighting (correct me if I am wrong). Don't know what the wires (brown) in the next box are for. These two boxes are high and along the corridor leading to my bedroom. Ideal spot for my Zigbee hub.
Possible to fix-up a power socket? What is the box with just the brown wires for?
Please help me out here. Thanks.
It looks like you are not in the UK (lucky person).
First thing to say is you must not presume anything when it comes to electrical safety!
However 'I presume' this is your property, or are you a tenant?
Does your Zigbee hub have a power brick type plug, and if so what sort of socket is required for it?
In the UK it's not allowed to fit a 13A socket on a lighting circuit (assuming that's what it is?)
Do you have a multimeter, know how to use it, and are you competent to make domestic electrical connections?
If all the above are true, there is probably a solution for you.
Hi Avo,
Thank you for the response.
I am in Singapore (not sure about the "lucky person" bit) and it's my property.
The Zigbee hub is power by a USB phone power brick like the one in the photo. Using my old iphone charger head plugged into my 220V wall socket in my room now. Works fine but I figure the location can be better. Therefore, trying to understand the wiring in the corridor leading to my rooms (which will be more of a central location for the hub).
About the multimeter - am planning to get one soon. (any recommendations?). Using it shouldn't be difficult, I think.
Competency - I am reading up and watching youtube videos on how to swap out regular switches and plugs with smart ones. Done 2 and am quite happy with my performance. Want to equip myself with more knowledge before more work in the way of smart home stuff.
I appreciate the safety bit when it's about electrical stuff and that's exactly why I looking for expert advise.
The first part sounds complicated. I don't think I follow you.
The second part - will something like in the my photo do it?
Any idea what these live wires are for in the enclosure?
@VeeCee I have removed some posts from this thread due to inappropriate advice. From a distance we have absolutely no idea what those wires are doing so I suggest for your own safety you seek the services of an electrician.
Thread closed.
Status
Reply to Can use wiring meant for switch for power socket? in the UK Electrical Forum area at ElectriciansForums.net
Hi, i live in a new build house where they builders have left a junction box on the outside of my house. In the junction box there is a 6mm twin...
My wife has a electric heated airer, our dog chewed through the cable and I thought it would be no different from rewiring a plug. It's not. I...
I have pulled out an old evaporative system I purchased many years ago from storage to have a look at it and see if I can get it running. Was...
This weekend I was replacing a hall light fixture in my old home (rewired circa 1980/90's) and noticed the work was done using one of the exposed...
