Discuss CCU vs Outlet Plate in the UK Electrical Forum area at ElectriciansForums.net
zakjay
What's the difference between a cooker outlet plate and a Cooker connection unit? Is an outlet plate for when a cooker doesn't have any way to connect to circuit from the cooker unit itself and that's when you attach an outlet plate to the wall and then have cable go from the cooker to the outlet plate and then to a CCU, then from the CCU to cooker Isolator switch? or is that overkill and I'm misunderstanding it completely. Any clarification would be greatly appreciated :)
Reply to CCU vs Outlet Plate in the UK Electrical Forum area at ElectriciansForums.net
A friend's partner has an interesting fault, if it is a fault. She sets the shut down timer on the cooker and when the timer goes off (which in...
I have a selection of brand new electrical items 6 MK 422. 1g white telephone socket outlets 2 MK 3632. 2g white moulded...
Mobile home outdoor power supply is a pedestal that power to the mobile home plugs in much like an RV. The main power supply into the mobile home...
Hi All, We have an old Country villa in Spain. The housing electrics were not good so the house recently has been completely re-wired to a good...
Last week I was working in a house changing a socket. When I turned the main switch back on and the MCB on the socket didn't energise. I went and...
