- Reaction score
- 7,774
yeah ,why is that buss bar half hang out top pic and bottom pic?tidied up the CU today, any constructive comments + or - ??
Discuss Continuity RFC error??Help please in the The Welcome Forum area at ElectriciansForums.net
Cable entries are a bit rough, no grommets, not sure about the IP rates on the side, and the bottom internal could do with a clean, plus not keen on the curls made in the Live Brown conductorstidied up the CU today, any constructive comments + or - ??
Cool thanks. bottom picture is before top is after. I just used the existing 10 year old wiring & CU already installed I should have bought some grommets though. I did clean the bottom tray. I don't think I did too bad for a first time touching a CU. Thanks for the comments though.Cable entries are a bit rough, no grommets, not sure about the IP rates on the side, and the bottom internal could do with a clean, plus not keen on the curls made in the Live Brown conductors
Ditch the Wylex MCB and get a Crabtree
fair play to you there. it's better than a lot that i've seen.Cool thanks. bottom picture is before top is after. I just used the existing 10 year old wiring & CU already installed I should have bought some grommets though. I did clean the bottom tray. I don't think I did too bad for a first time touching a CU. Thanks for the comments though.
They emailed me the guide same day thanks for the advise
Reply to Continuity RFC error??Help please in the The Welcome Forum area at ElectriciansForums.net
