Discuss Cooker Switches in the UK Electrical Forum area at ElectriciansForums.net
J
JC23
Hi.
Not in the electrical trade so please bare with me.
I need a cooker switch replacing in my kitchen, it has a socket incorporated with it and is an old looking MK one. My fuse board has half of it RCD protected, all the 32A circuits but not the lighting or the cooker circuit. When I get an electrician in to replace the cooker switch, I want to have one with a socket incorporated still as this is what my fridge freezer is plugged in to, will he need to add in an RCD/change my fuse board? There is no room to add another breaker on the RCD side. Or could an RCBO be used instead maybe?
Just like to know so I know roughly what I will be having to pay out for.
Thanks.
A simple accessory change will not require any further changes to the installation..... Unless the Zs test reveals any issues
Agreed, if it one of the square style units the MK part Nos are K5011 WHI for a flush fitting or K5001 WHI for a surface fitting, hope this helps.
Reply to Cooker Switches in the UK Electrical Forum area at ElectriciansForums.net
The electrician that installed my cooker circuit put in 10mm cable with a 32a fuse, a 45a cooker switch and 10mm cable to the backplate for behind...
Hi all. So I'm designing my new kitchen and trying to plan where things will go. I currently have a 6 switch panel for the appliances (hob...
Hi all, I'm about to replace our kitchen and one of the upgrades is to install two full size ovens to replace the original twin over under...
Hello All. I'm quite new to this game and gaining experience, but going well in the main. My customer wants to feed a Hob ( on island in centre...
Hi All, We have an old Country villa in Spain. The housing electrics were not good so the house recently has been completely re-wired to a good...
