Discuss Crimping Solid Conductors in the UK Electrical Forum area at ElectriciansForums.net
As per SJD, we call them solder sleeves in my neck of the woods. They're available from RS Components, Digi-Key etc.
They come in all sizes and configurations and the type we use you just strip the two wires, shove them in so they overlap 5 or 6 mm in the centre of the sleeve then use a miniature blowtorch to melt the slder and shrink the sleeve.
It used to be that they were only available in aviation and mil spec and cost a fortune but nowadays they're available all over the place in general electrical spec and they're much cheaper than they used to be.
Well I think this has gone a bit off the plot TBH. I can see the scene now, when "Mr Electrician" turns up to "Mr DIY" house and draws a sharp intake of breath. "Ooohhhh my god, this is going to need a very specialist butt soldering-crimping-insulating whizzo to fix this one". Area to be taped off and risk assessed.
FFS just crimp the cable, stick some heat-shrink over it and then make good, test it and jobs a good un. £85 please mate, next......
I disagree, I carry a selection of ordinary butt crimps, heatshrink butt crimps and heatshrink solder butt connectors. And select whichever is most suited to the task. They are all in the one selection box. Perhaps takes a few minutes longer with the solder type, but it really is no trouble at all.
The problem with crimping is that I've always found it's difficult to gat everything lined up and get the damn crimp tool in when it's half way down a wall and plastered in on either side.
The solder sleeves are easy, they come with the solder and flux already inside them like a Yorkshire plumbing fitting. You just put the (clean) wires in apply heat.
What about heatshrink solder butt connectors.
For example: http://www.workshopsupplies.co.uk/contents/en-uk/d1434_Heatshrink_Solder_Butt_Connector.html
I've used these a few times, using a decent electrical heat gun with a selection of clip on nozzles, choosing a nozzle to suit. You do have to be careful to avoid overheating the joint, it is possible to char the whole joint (which means starting again).
Plus at least one glue-lined heatshrink for an outer sheath.
I've seen those today, but I think they are designed for stranded cables, i.e. the strand's are mixed together then soldered
Absolutely, the cable has been ruptured along its length with no free play, anything is going to be a compromise. If you are confident you can make a perfect soldered joint, then fine, probably best way. But you have got to rake it all out, fix it, make it good..... There is only a maximum you are going to get away with for this sort of work, you can't take all day?
Agree with the above posts, decent crimps and decent adhesive-lined heatshrink can make a very good joint. If done correctly then it certainly isn't going to come apart when buried in a wall ! Daz
Thanks for the replies chaps and views, seems crimping is not frowned on then.
Incidentally, I quite like the ' heatshrink solder butt connectors' as another option, but it seems they primarily designed for stranded cables? I seen them on Ebay, Amazon etc, but not shown as specifically for solid cables, guess you just overlap conductors, but does that provide a good soldered joint?
Inline crimp cores individually. Heatshrink cores obviously using correct colours. Raychem over sleeve over the heatshrinked joint. Raychem = Heatshrink used as an oversleeve heating releases a glue which enables the oversleeve to stay in position.
"Other brands of heatshrink sleeving are available". Daz.
Reply to Crimping Solid Conductors in the UK Electrical Forum area at ElectriciansForums.net
