Discuss Do air-to-heat systems work with smart thermostats and radiator valves? in the Central Heating Systems area at ElectriciansForums.net
apochi
Hi everyone, my house has an air-to-heat system that generates hot water in a boiler. This boiler is then connected to the central heating radiators and we've got two thermostats (one on each floor). This is a new build.
I'm considering installing a smart thermostat and smart radiator valve system in the house so I can have a multi-zone control over each partition's temperature and, possibly even, shut down certain radiators on particular unused rooms of the house.
Would I be able to install this system on my air-to-heat heating? If I shut down water flow (with the smart radiator valves) or reduce it to some of the rooms in the house, would this mean that I would be spending less energy and saving some money?
Thanks!
Reply to Do air-to-heat systems work with smart thermostats and radiator valves? in the Central Heating Systems area at ElectriciansForums.net
I've always thought I was quite good a wiring heating systems, I can do Y plan, S plan, UFH set ups, "normal" thermal stores etc, you name it and...
At the moment it depends on the weather on how well the central heating works, the main problem is the Nest Gen 3 thermostat only measures the...
Hi. I'm installing a wet underfloor heating system in my own house. What would you recommend as the best smart control system? I can hardwire...
Hi all looking for some helpful advice I'm an Aussie so go easy on me, I have a good mechanical engineering head but first time plumbing and...
I have a fully pumped Y plan heating system using a Potterton EP2 programmer. Drayton MA1 Diverter valve. I have just replaced the Actuator head...
