- Reaction score
- 25,466
Plastic plug will hold a damn sight longer than those tie bases or use Wall Dogs, aside from looking awful the whole lot will just drop down in the event of a fire.
I can’t say I know the difference but professional curiosity has got the better me and would love to know the different ratings between the two ? also all this will be above a suspended ceilingPlastic plug will hold a damn sight longer than those tie bases or use Wall Dogs, aside from looking awful the whole lot will just drop down in the event of a fire.
The fact it is above a suspended ceiling is not relevant correct support is still required.I can’t say I know the difference but professional curiosity has got the better me and would love to know the different ratings between the two ? also all this will be above a suspended ceiling
I love to use the plastic coated metal saddles.dont Know why people bother with saddles , just install metal linian clips when putting up conduit
When all the apprentice has to do all day Is screw rods inView attachment 28533
A Containment catastrophe
Apologies for the orientation
That plastic conduit might be a bit vulnerable if they want to keep giraffes in those stalls. ?View attachment 65187mild improvement on our behalf won’t lie ? to all haters ties will be swapped to metal Thursday when I’m back, struggled on my own for a day View attachment 65193
That be one of them ‘leave it to the homeowner to contact the DNO to reconnect the earth‘ which they probably will never do.Not quite sure that this is a PME connection ? and that 10mm earthing conductor is looking very hopeful ?
I suspect there's an earth rod somewhere or the system earth is reliant on the gas and water bonding ? SSE are pretty good at coming out for PME connections so I might see if I can use that 10mm to pull a 16mm through to the MET.That be one of them ‘leave it to the homeowner to contact the DNO to reconnect the earth‘ which they probably will never do.
leaving the entire home unearthed until the next rewire in 40 years time
Arthur: What happens if I press this button ?When u ever I see dire warning not to use a switch I always get a voice in back of my head saying "Switch it switch it switch it"
In case you really don't know its a Cold Water Tank overflow fitting.Is that a plumbing fitting?!
Necessity is the mother of inventionIn case you really don't know its a Cold Water Tank overflow fitting.
