R
Robinson
Large 3 bed house
Dont know what to say to person who asked me. really seems like it could be a fairly high price but not out of ordinary bad.
35 double sockets (all chased and made good)
2 x floor heating supplies 13amp
3 x Cooker Supplies. (2 ovens,1 ceramic hob - each 32 amp)
Boiler supply and controls
Alarm supply
Smoke + Heat detection, hard wired.
2 x extracts
1 x over head extract supply
45 x down lights (all in lath n plaster)
8 x IP shower down lights (in lath n plaster)
All lighting apart from 2beds, utility and bath to be run from Wireless control units with multiple zones
Fittings (Downlights only) and intelligent lighting system client provides, Just fit, wire and program.
2 x outside PIR flood lights
Audio cables run in to locations for speaker system (bed, Kitchen, dining, lounge)
Main earth bonding
13 way CU (crabtree)
All Sockets switches isolators anything visible is in G&H white powder coat flat plate metal (£10:50 each double socket, £500 for all)
G H FW10W Flat Plate Matt White 2 Gang Double 13A Switched Plug Socket - Ashdown Light Store Switches & Sockets
Total cost : £7000
Are you suppling and installing or installing, £7K for installation and Certification sounds about right but it really depends on the building, and as you mention Lathework I assume its old I do not envy you trying to get neat holes in that at all,
Pict
Just quoted eleven on a barn conversion with around about the same speck , maybe a few more down lights and that was with a extra thousand put aside already for fittings of their choice and they will pay extra if they go over that !
Thats a lot of materials and a fair bit of work,what do people want,cricky should be more,for me downlights do not go well with lathe and plaster
So its actually stated 7.1 K . Client buys all spots, and lighting control system.
Everything else was in the 7.1K. inc those posh sockets. total socket and switch cost was £500.
I believe that there 300m 2.5, 200 1.5m, 100m 3core, 50m 6m as far as cable was booked.
But i the control system is wireless so no switch drops.
Have a look at toolstation they have two adjustable hole saws which also have a cowel to catch the dust, have used one for years. Plus they come with different blades for different materials. Just done a job and it didnt damage any of the other lathe ceiling as it can be a bit fragile in older propertys. Plus they save you getting a face full of dust and soot.
Reactions: 1 person
The link you put up seems an expensive place to buy gear, sure you could better them prices ... tool station , Sfix or a local whole salers, or is that make specified ?
Ste
Always cut holes slightly smaller and never breakaway the wooden strips as ceiling will start becoming loose try cutting them with the hole saw for the spotlights not putting much pressure on them. We work with them all the time in london very annoying.
slowly slowly catchy monkey with lathe and plaster ceilings. Slow, light pressure don't end up trying to patch it when it goes wrong. last one i did when horribly wrong - more ceiling on the dust sheet than above me. still having nightmares
you can buy the cowel thingy seperatly If memory serves me right itd something like "Dust Elimination Tool" I got one from CEF Slow speed on drill new holesaw dont put to much pressure on it
The lighting control,wiring to control boxes and speaker cables ( mind run these well away from mains as interferance WILL happen if run to close ) probably wont be simple allow extra time for this Had a jod few tears ago client speced Wandsworth flat plate fittings we had to fit 35mm back boxes due to ammount of the fitting behind it (allow for extra chasing and cutting out the boxes and PRAY its not black brick or dry old mortar that cant be chased without wall falling to bits ( Ts N Cs to cover this)
Ste
Make was only one could find that cheaper white powder coat flat plate, BUT with WHITE rockers, all cheap ones i found were silver or chrome rockers......any links appriciated
Dust dont matter so much as not occupied BUT i would prefer much less on AND in my eyes nose mouth etc etc
i just use one of these........
images
Does this seem reasonable?
Australia
Robinson,
Robinson,
