Search the forum,
Discuss Earth Leakage Relay connection with normal CT in the UK Electrical Forum area at ElectriciansForums.net
I have just been looking online for the earth fault and earth leakage relays from Delab. Wiring diagrams differ as it shows a CBCT for the leakage relay and CTs for the fault relay.
I’m posting this question because, one of my friend are studying Electrical program. There instructor saying CBCT will create using 4Nos of Normal CT. I’m also not believing this. That’s why I’m discussing. I think DELAB EFR will not working using CBCT. Only ELR will work. I’m right? And also DELAB ELR will not working using normal C.T. I’m right? What’s your idea?
CTs can be used for overcurrent and fault relays but a CBCT is used for a leakage relay but never say never. If you used CTs for a leakage relays to me it will be constantly tripping, a CBCT doesn't give an output when no leakage is present.
Reply to Earth Leakage Relay connection with normal CT in the UK Electrical Forum area at ElectriciansForums.net
Hi all Suggestions please. I’m working on a 3 phase shop install with a bunch of typical circuits. As each cct is energised the earth leakage...
Hi all, There's 2 single fan ovens in the house my mother recently moved into. Posh elecronic AEG units. It's been sat empty for a year, so the...
I am trying to understand how a relay system works and have designed a circuit and a ladder diagram all as attached for an 8 PIN relay, a current...
Hi I currently on a job where the garage is having an office built above it with solar panels installed on the roof. I have ran a 16mm 3 core...
Good evening! Don’t have a huge deal of experience with fire alarms but having to work on a conventional system at the minute with various...
