Discuss Eddy in the UK Electrical Forum area at ElectriciansForums.net
cliffed
Supporter
Just found this on another forum… no comments on the actual pic…this can’t be right can it?
Taking the single cores through separate holes like that is a big no, no.
assuming of course that the base of the enclosure is steel and that no other provisions have been made to prevent eddy currents.
Agree with you ,but we have no other information, just a picture of an isolator with singles entering at the bottom.
Is the base plate ferrous? if so has it been slotted in line with best practice? for all we know the cable eateries may have been made in an insulating material, no info on that from the poster
Well I can't see where the metal enclosure is earthed??
But without a picture of the entry plate it is hard to tell whether the tails have been correctly installed to prevent eddy currents
Agree that it's impossible to tell whether it's OK or not. If there is a slot between the holes or the plate is non-ferrous, it's fine. If not, it's not, although currents of this order (63A) through unconnected holes in a mild steel gland plate do not usually cause any significant issues in practice.
Hello to all,
Rather than start another eddy current thread, thought I'd just tag onto this one.
Cables contained in metal trunking which is bushed to the side of a 12TP dis board. Lives and neutrals go through one 50mm brass Bush into RCBOs. The earths go through another 50mm hole which is in line with the earth bar.
Will the brass bushes prevent eddy currents as the brass isn't magnetic?
Reply to Eddy in the UK Electrical Forum area at ElectriciansForums.net
hi all, What are your thoughts on how the 6231 cables been terminated? Will aluminium cause eddy currents? Thanks
On a domestic Cu 60 amp would live and nuetral tails cause eddi currents of any significants if the tails were run in sperate metal conduit but...
Hi all. I am installing some metal trunking vertically in a meter cupboard to contain all the meter tails for an apartment block. I have 5 sets...
Hi Guys Been asked to install Eddi & Harvi units, for TP new build we're just finishing off. PV inverter is down in basement plant room right...
I'm trying to find a way of energy logging a home to help plan a battery installation. Ideally tracking import by hour and displaying some...
