Discuss Electric cylinder boiler question in the Central Heating Systems area at ElectriciansForums.net
Hi,
I have bought a flat with an electric boiler - the flat is all electric. The boiler is a Vented Cyclinder ; the exact title is a "Kernal Plumbing Unit" - as below:
Kernel Plumbing Units
My question is:
1. As this is not gas powered - do I need to service it? It is 10 years old, but looks OK and has been working fine
2. If I do need it serviced once a year - who do I call - an electrician or specialist plumber?
3. I can see Gas Boiler breakdown insuarance (eg from British Gas), but I cannot find anything for electric boilers. Does it exist?
Thanks for any help - I am new to all this,
Alex
There isn't a lot to maintain on these units looking at them if it's 10 years old it may be worth changing the washer in the ball valve on the header tank as a precaution but that would be about it and certainly not worth paying an annual maintenance contract
Thanks for your help - so no annual contract needed
One final question: do these cylinders need to be cleaned out / descaled - like every 10-20 years??
I have never heard of or know of any body that has had a hot water tank de-scaled. I have replaced failed immersion heaters that have been heavily scaled but as whether that caused the failure is open to debate
If you are concerned about scaling then you could fit a scale inhibitor have a look at this link Calmag | Do you need a softener or a Scale Inhibitor? to help you decide
Reply to Electric cylinder boiler question in the Central Heating Systems area at ElectriciansForums.net
I've always thought I was quite good a wiring heating systems, I can do Y plan, S plan, UFH set ups, "normal" thermal stores etc, you name it and...
Hi, Small flat, currently has a small'ish feed water tank, top of a cupboard, feed through a wall into under stairs cupboard. Hot water tank...
Hi, I'm having a new boiler fitted in a new location. I need to provide power for the boiler which I'm looking to do myself. Boiler: Ideal Logic...
Hi, my wife and I have decided to bite the bullet re the costs of an electric combi boiler in an off-gas grid one bedroom flat where space is so...
My company has recently done some air source heatpumps which require DNO notification and EV chargers which also require DNO notification. On an...
