Discuss Electric Shock from Shower in the Australia area at ElectriciansForums.net
If there are no IR faults,earthing and bonding are in place,and adequate earth fault protection is provided they wont be getting shocks.....as the others have said this is what you need to check,
Hi,
Do an insulation resistance test on the cable supplying the shower.
Sav
Unless there is no RCD in place and there is an internal problem with the shower.
Reply to Electric Shock from Shower in the Australia area at ElectriciansForums.net
