714gold714
hello there first time poster here so go easy on me
Got a job to look at and was wondering if you guys could help got a hot tub supply to run in, I was thinking of coming out of existing fuseboard and running a 4mm cable to the shed with rcd consumer unit with earth stake. the thing I need abit of advice on is the hot tub would need some sort of isolation the guy said its needs to be 25amps supply so odviously a normal switch fuse would not be up to the job and was thinking of fitting a rotary isolator? would this be ok and where abouts would it be ok to fit the isolator? due to zones. Sorry I have not done a supply for a hot tub before so just looking for advice. The job will also be signed off.
any help appreciated
