Discuss Emergency Lighting - Understanding in the Lighting Forum area at ElectriciansForums.net
Kindly refer the attached Image. There are 2 Places at which I can give reference signals for Emergency lighting.
1. At MXC
2. At LTC (Unswitched & Switched)
What is the difference between the above two? why there is a need to provide input at two different locations?
The LTC is part of the EMEX MXC automatic emergency lighting testing system, and can control the lamp and dimmer signal when testing. It measures the lamp power consumption and communicates this and the lamp status back to the EMEX central PC using power line communication via the MXC substation. It is fully addressable and programmable for any lamp type or configuration. This is done in situ from the central PC.
Reply to Emergency Lighting - Understanding in the Lighting Forum area at ElectriciansForums.net
Hi Guys I've fitted a few emergency lighting circuits to both domestic and commercial installs before, I've come across one I can't get my head...
I tested a self test emergency lighting with three gears .While testing 2 of the gear doesn't passed 3 hour test but 1 Did Wit the same battery ?Why?
Hi I'm in need of some advice. First of all i'm not an electrician but do have an understanding of electrics as i come from an electronics...
Hi guys, Been asked to fit 2 lights and a switch, which in reality turned out to be rewiring a multiple PIR setup to a single switch, adding...
