K
kevster
I recently installed 6 no. One electric 6' twin ncf fittings.When energised, the CU rcd tripped Wiring tested fine and eventually i found that all 6 fittings tripped an rcd adaptor when tested individually. Has anyone else had a similar experience? When the fittings were swapped for Dakal ones everything was fine. several hours of time was wasted diagnosing and then rectifying the problem.
welcome to the forum, sounds like you were very unlucky and got a batch of faulty lights,just out of interest did the rcd trip with lamps out? or did you not try?
faulty ONE fittings.
kevster,
SYKRAPS,
