Discuss Garage electrics - running cable through garden in the UK Electrical Forum area at ElectriciansForums.net
Hi,
I have asked an electrician to install electrics in my house's garage. I'm happy with the electrical work he has proposed and quoted for, but I wanted to check his approach to running the cable to the garage.
A armoured cable will exit the house through the meter cupboard on a side wall, run down the side of the house, and then across the garden to the garage. Most of the trench will be fairly easy to dig - the problem is that there is a brick path running along the side of the house. My electrician recommends taking up the brick path and its concrete base, digging the trench, and then re-laying the path afterwards.
Is this how all electricians would approach it, or would some electricians have the equipment to tunnel under a narrow (1 metre) path?
A bit of spade and jackhammer work for a 1m garden path is what I'd be doing. If you internet search on directional drilling and you'll get a flavour of what's involved to bore it.
Just make sure your aim is good :)
Regarding the regulations, an outdoor SWA (Steel-Wire-Armoured Cable) doesn't have specific advice, other than when burying it, it must be at a reasonable depth given it's location/path/route, with regards to the potential activities which may disturb/damage it.
It seems reasonable to bury the cable under the path to ensure it's kept safe and is unlikely to be damaged by gardening, however I understand the cost and inconvinence of this method and there are other possibilities.
If it's clear to run the cable under the lawn or flower-beds, this is entirely possible, however it would need to be buried significantly deeper to make sure it's not disturbed/damaged by gardening, which can also incur a higher price.
Conclusion:
The depth & location that the cable is buried at is mostly down to the electricians discretion. Burying the cable under the path is probably the safest option, but with reason, I'm sure they'd be happy to look at other possibilities.
Just a comedy,only fools n horses story,but a mate of mine,used an auger,to put in some anchors,for a swinging chair...
He picked up the flexible cable,in a plastic conduit,for his electric gates,which went to a plug-top,in the front room...
It wound ALL the cable round the end of the bit,leaving the severed plug-top,still stuck in the extension socket,at the edge of his floor boards - but not before it dragged the tele,sat-box,dvd,glass table and all the ornaments,to a pile,in the corner :(
Regarding the regulations, an outdoor SWA (Steel-Wire-Armoured Cable) doesn't have specific advice, other than when burying it, it must be at a reasonable depth given it's location/path/route, with regards to the potential activities which may disturb/damage it..
Which is yet another glaring omission from said regs. All they need to do is add a table of "guidance" then that would help immensely.
Reply to Garage electrics - running cable through garden in the UK Electrical Forum area at ElectriciansForums.net
Help please! I need a Tesla Gen 2 EV charger fitted in my garage which is 22m from the consumer unit. My electrician is proposing to route a 6mm...
Hello all, I need to have an electric car charger installed but at the moment I'm puzzled about what my options are. My garage is at the back of...
I’m planning to run an electrical sub-panel to my detached garage (about 150’ away) and run it off my 200 amp home panel. I live out in the...
Hi I've got an new outbuilding that needs power run out to it, the building is very close to the house and the original plan was to run an...
Hi all. I've recently bought a bungalow. It currently has a armoured cable between the house and garage which spans less than 1 meter. The height...
