Discuss GN8 9.3.1 Calculation of csa – armoured cable 118 in the UK Electrical Forum area at ElectriciansForums.net
there are no requirements for supp or main bonding within the building supplied in question , SWA only used as a CPC on sub mains and not supporting main bonding.
But yes quite right i think its a factor of 6 or something?
its and existing installation supplying a brick building with just a few sockets and lights.
an 2 core SWA 50mm sub mains protected by a 80a BS88-2 fuse supply the fuse board in the outbuilding
Reply to GN8 9.3.1 Calculation of csa – armoured cable 118 in the UK Electrical Forum area at ElectriciansForums.net
Hi all , The measured value of loop impedance for a circuit is 2.4Ω. If the temperature at the time of the test was 20°C and the cable is 70°C...
Hello, Does anyone know if Trimble can be used for cable calculations for equipment with an IT earthing system? If not could you please point me...
Hello, hopefully ive got this right but if someone can check over my maths for me, id appreciate it. Im needing to install a new supply cable...
Hello all Am trying to calculate suitability of using swa armouring as c.p.c. It is a 6mm 2c supplying a log cabin. From table 54.7 the...
Hmmm, Could anybody tell me which table I use for calculating armoured cable sizes in the on-site guide? I'm self teaching and failing :-(
