Anybody know of a good brand of exterior wall light that looks similar to the light below, needs to be able to accept conduit from both sides.
Not an Electrician then?Would prefer not too as not a fan of the look personally, I would like the fittings flush on the wall then conduit coming out either side as there are four of them in a row.
The OP wants them flush with the wall KevOnly problem with conduit at either side, it's a bother to replace the light in the future, use a T box and enter the light from the top.
Design Plan are a pretty good manufacturer.
Just the sort of install where customers don't realise the methods that need to be employed ti suite their unreasonable needs.The wall has a top ledge which sticks out further than the wall so I think it will look a lot smarter with the top of the light sitting against the ledge and sitting flat on the wall and conduit in between the fittings.
