Discuss Help with light fitting in the UK Electrical Forum area at ElectriciansForums.net
I am trying to put a 5ft fluorescent light in a garden office on a Dimmable switch. I got standard 230v light fitting which requires a T8 lamp. I did get a Dimmable halogen t8 lamp and put it on a standard dimmer switch but unfortunately it is flickering when dimming.
does anyone know a Solution for this?? Is it the dimmer or the lamp?
i have been looking for a Dimmable LED T8 tube lamp but can’t seem to get them anywhere.
if anyone knows a Solution to this it would be much appreciated as trying to get this done ASAP.
Fluorescent lamps can be dimmed with a digital ballast, which would mean changing the control gear within the fitting you have.
But really? A garden office? Why do you need to dim the lighting?
Edit, post crossed with Freddo's
I said the same thing but the customer wants it.
Okay so changing to a digital ballast will work with a Dimmable lamp and standard dimmer switch?
Reply to Help with light fitting in the UK Electrical Forum area at ElectriciansForums.net
I fitted a dimmer switch by daisy chaining the dimmer switch to a normal plug. The challenge is the light flickers at random intervals. If I take...
R
I am looking into LED lighting for a Grade I listed church, parts of which are 800 years old. The lighting must be simply dimmable with a colour...
The following light fitting from Dumelm takes GU10 but states "Dimmable No" but I can't see why with the correct dimmer switch and dimmable GU10...
Morning All Got little bit situation going on, causing multiple visits (luckily only 2 mins drive from where we are.) Client not 100% happy with...
Hi guys, hope all is well. Getting hallway and stairs replastered/skimmed, do the light switches/light fittings need removing altogether for it...
