Discuss Help With This Question? in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
M
MattyH
I have got my 203 exam tomorrow so I am reading through my notes, but I have forgot how to do this question:
The inductive reactance of a 100 mH coil when connected to a 50 Hz supply will be:
A) 5 Ohms
B) 20 Ohms
C) 31.42 Ohms
D) 31.42 Kilo Ohms
Also any tips on the 203 exam?
A) 5 Ohms
B) 20 Ohms
C) 31.42 Ohms
D) 31.42 Kilo Ohms
Good luck on your exam, I have just passed my 301 and I wish you all the best.
The biggest tip I can give you is to read the question slowly to ensure you aren't missing something. (like the thing you missed in this question)
in one of the questions in my mock exam I had an answer of 3183 ohms. None of the multiple choice answers was near that but after 20 minutes Of looking at it I realised that one of the answers said 3.18 K ohms which is obviously correct.
Have you looked on the Swindon massive revision site?
A) 5 Ohms
B) 20 Ohms
C) 31.42 Ohms
D) 31.42 Kilo Ohms
Before you can answer the question do you know the formula for Inductive Reactance? This is the first starting point mate...once you've got that, you have the answer..
If you don't know it I can remind you of it, if you like??
Thanks for the replies guys! Yeah. I just realised I had to change the mega henrys into normal henrys (divide by 1000 and got 0.1) and i got 31.41. but the closest answer was 31.42 which i presume is right! Also I am using swindon massive.
Note that the value you had was milli (m) Henrys not mega (M) Henrys, but your calculation is correct.
Also does L stand for reactance and what does NF stand for?
Lenny has given the answer as well as Ebow but the NF to which I think you are referring is the greek letter Pi (3.14159...) multiplied by frequency f. It does look like Nf.
Reply to Help With This Question? in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
A coil is connected to a 100v a.c with 20ms, and supply current taken by the coil is 6a calculate the frequency (50Hz) the overall impedence (16.6...
Hi Guy's, I'm revising for my 18th amd 2 and came across a question that has me a little confused. I think its probably the question is badly...
Hi, I would love some help understanding an issue I’m having on a 16mm SWA cable running from the CU in my house to the CU in the shed. I believe...
Hello. I’ve been racking my brain all day with this. Here is my situation and question: I have some OEM ambient lights in my vehicle. They are...
Hey guys. I am currently studying for 2396 city and guild electrical design exam and I'm stuck on this question. Its asks to determine the...
