B
brizospark
Guys,
Property I am working in currently has storage heating which is being doen away with - as this is the case the client wants the off-peak supply completely done away with.
Only problem is that at the moment their hot water is controlled by a combination of off peak supply, solar and with a boost switch in the kitchen.
If I want to do away with the off peak altogether can anyone give me a recommendation for a suitable control system which would replace the current set up?
Many Thanks
If the solar is just using up excess generation via a immersun or such like then this can be connected directly to the off peak immersion element.
The off peak element would just need a timer control for normal use and the boost switch in the kitchen can stay as is, assuming it is supplying the on peak element, though if it is just a switch then a time limited boost may be helpful.
Hot Water Controls
brizospark,
Richard Burns,
