Discuss How can I safely join two ends of this wire? in the DIY Electrical Advice area at ElectriciansForums.net
Thank you for taking a look at my issue.
The pictured standing lamp had a foot actuated on/off switch which broke. I would like to join the wires. My first thought is to twist them together and cover with electrical tape, is this safe? Would someone be so kind as to suggest alternate ideas that would look better?
The plan is to then plug the lamp into a foot actuated dimer/on/off switch.
Thank you,
Pete
You need something with cord grips to make the joint safe, not just wrap the wires together!
With the example below you could remove the brass block on one side to acccomodate the unbroken wire you have, rather than cut it. One less joint in the cable!
eg White 2 In Line Connector for 2 Core Flex - https://www.lampspares.co.uk/white-2-in-line-connector-for-2-core-flex/?
PS you can get black one's if you prefer!
just noticed you are in the USA - I presume Home Depot etc. would have similar products available?
Twist and tape is dangerous. We get little baby resin joins that are ideal for repairs to small diameter trailing cables, maybe shop around locally for something similar.
Reply to How can I safely join two ends of this wire? in the DIY Electrical Advice area at ElectriciansForums.net
I am trying to understand how a relay system works and have designed a circuit and a ladder diagram all as attached for an 8 PIN relay, a current...
Hi, I am looking to convert a 2 way light into just control by single switch. I have searched and looked for similar questions here, and found a...
Hi Everyone, New to the forum but hoping I can find a little help with my restoration project... I am adding a secondary wiring "system" to my...
