Discuss How to actually TT a shed/garage? in the UK Electrical Forum area at ElectriciansForums.net
I see no reason not to use a stuffing gland as long as the cable is properly secured by cleats etc.
A bit of heat shrink over the end of the cut end of the armour will keep it neat, just remember not to shrink it until after the Zs test
I'm going to extend the example now!!
If the shed/garage is going to have sockets/lights AND an electric vehicle charging point would you need to take 2 separate supplies (i.e 2 x 2 core SWA) as the charging point needs to be on it's own dedicated circuit? Or could it be on it's own dedicated circuit from the Garage CU? I would have thought the former as otherwise it's not really a dedicated circuit.
Apologies if this has been covered but If supplying a ev point I think youll need something like 40a (min depending on size of charging point) with no diversity allowed? (not done the course but im sure thats right) so in a normal house you'd probably split the tails into a new small board purely for the ev. Based on that if you were powering a shed that subsequently supplied an ev you might have to take that into account? If just a shed then its unlikely youll be using that much power at one time but might be worth considering??
Reply to How to actually TT a shed/garage? in the UK Electrical Forum area at ElectriciansForums.net
TNC-S main supply with 16mm swa supplying garage consumer unit from main consumer unit in house, then 4mm swa supplying pond equipment through...
The earthing arrangement where the hot tub will be installed is formed in the TN-C-S system. I want to install the sub-main distribution circuit...
As the title says, I am looking for a recommendation for an enclosure and gland arrangement to electrically isolate or divorce the earth/armouring...
5K
Hello all, Looking for help here as I've come across a strange call-out today. Bare with me here: Got a call from a customer saying they had...
Hi Guys/Girls A quick question. Would I need to TT a stand alone socket detached from main building (TNCS) that could be used with a Class I...
