Discuss HPS lamps in the UK Electrical Forum area at ElectriciansForums.net
Hellmooth
Went to a customers today to with some HPS lamps for fittings bought by himself, the only info on the fittings is HPS 70w lamps, so picked some up from wholesalers and they didn't work, the lamp box says must be used with correct ballast, can anyone tell me how many different options there could be for a HPS fitting? Wholesalers obviously shut but that was the only lamps they had anyway!
have you checked whether it;s internal or external igniters?
Thanks guys, now I think of it the wholesaler did mention about an igniter........or ignitor.....? :smile:
These lamps obviously don't have and that is the problem, thanks again much appreciated, merry Xmas!
those with integral igniter are marked with an "I" (in a triangle)
Looked them up on eBay, can order them in but was hoping to get them sooner, do you know anywhere that would stock them? Yesss only have the external igniters!
Reply to HPS lamps in the UK Electrical Forum area at ElectriciansForums.net
Had a customer message me before I went to do a job asking if I could put a new bulb in a spotlight while I was there, so I picked up some LED...
Why is this still a thing, just done a quick calculation with the TLC volt drop calculator and if its a non lighting circuit the recommended size...
Hello gents I'm just after some clarification, I have a kitchen light fitting that uses a 2D 28W compact fluoresent lamp that I'd like to...
Hi everyone. Hopefully someone can help with a little mystery i had today. The issue is fixed but I want to understand what was going on to help...
Hi all, Got an antique light fitting that for some reason she wants putting up (can't say I love it haha) however it didn't come with any...
