Discuss Ignition problems with 1964 FJ40 V8 swap in the DIY Electrical Advice area at ElectriciansForums.net
jp_waltz
Hi there…I’m hoping that someone may be able to help me identify an electrical part of my ignition. For reference I have a 1964 Toyota FJ40 with a V8 swap (1995 Chevy TBI) that I did not do. When I started it a couple of days ago the starter appeared to stay engaged and smoke started coming from underneath the dash. I think I narrowed it to this black square in the picture. There is one wire going into the top that is connected to a junction that sits on top of the steering column behind the dash. The other wire comes from the bottom and runs into a five prong relay. There are several other wires that are part of the black square but were cut and taped prior to me buying the vehicle. It melted a hole into it and now I can’t get it to start. It cranks, but no fire. Any help identifying this part is greatly appreciated.
Thanks in advance
Paul
I wonder if it's just a commoning block that joins all those wires together? Difficult to tell. Will the plastic case split apart?
Reply to Ignition problems with 1964 FJ40 V8 swap in the DIY Electrical Advice area at ElectriciansForums.net
Hello and Happy New Year. It's not starting too well for me, excuse pun. Since Friday December 16th, The 2.4l Duratorq diesel won't start...
B
Hi, I’m not sure this post is really relevant here, but I’m looking for some advice about some electrical work that was undertaken at my home...
F
Hi everyone this is my first post on here so sorry if its not in enough or too much detail. I have an audi s3 2001 plate, recently I have started...
GaryM
G
C
Hi forum, This is my first post so i'm not even sure if i'm in the right section for this... Anyway i've got an intermittent electrical...
6K
blackiel
B
