Discuss Jointing 5 core 6mm non SWA cables in the UK Electrical Forum area at ElectriciansForums.net
Hello
I need to extend 13 5 core 6mm non swa cables, the joint's will be outside - above ground with no weather or sun protection.
Any advice on the best product to use for this task would be appreciated.
Chris
A weatherproof enclosure fitted with DIN rail and suitable terminals.
Or a weatherproof enclosure and crimp connectors suitable to the cable type insulated with heat shrink.
Or a weatherproof enclosure and soldered joints insulated with heat shrink.
Or a weatherproof enclosure and wago 221-612 connectors (6mm Lever connector)
Or solder and heatshrink insulated and heatshrink sheathed joints.
Which weatherproof enclosure?
I was thinking something like a Wiska Shark connector or underground resin joint kit
For 13 joints/26 cables I would imagine quite a large enclosure, a rittal style cabinet with high IP rating would be my preference.
What type of cable is it?
Those shark joints look a bit rubbish iny opinion.
I don't know how well an underground joint will resist the effects of sunlight.
Each joint is in a different location so unable to use a single enclosure.
Installation will be in operation / direct sunlight during daylight hours for 10 years so I'm after good quality. The Shark connector does not look like much but I have been impressed with Wiska products
[automerge]1596054086[/automerge]
This is one of the cables: VDE 0267 IBECHTOLD 5x6 CE 11
I will be extending it with either a PVC type cable of rubber flexible cable.
I wouldnt say I am impressed with wiska products, the only product I use are their infamous joint boxes (308s etc) hich are good enough for the job but could be better.
That's an odd cable type, is this a specialist application of some sort? VDE 0267 appears to be a standard for MV cables as far as I can see.
Reply to Jointing 5 core 6mm non SWA cables in the UK Electrical Forum area at ElectriciansForums.net
Hi. Im looking for some advice when calculating submain cables. Basically there is a new connection of 80Amps that is to be used for a dwelling...
Hi there , is there anything else to consider when using 5 core SWA instead of 4 core + separate Earth in three phase installations for cable...
Hi All, Just looking for some advice: I'm in the process of updating an old cable calc spreadsheet that helps to spit out Zs and Voltage Drop...
Hi, I'm going to be installing an outdoor socket, have no problem with the outdoor/socket side, but when bringing the internal end or the SWA...
