- Aug 12, 2017
- 14,337
- 20,736
- 3,557,381
- 51
- If you're a qualified, trainee, or retired electrician - Which country is it that your work will be / is / was aimed at?
- United Kingdom
- What type of forum member are you?
- Practising Electrician (Qualified - Domestic or Commercial etc)
Ive got a customer asking me about an LED strip around the perimeter of a bedroom. There is an existing coving which will be removed, and a new one fitted a little lower, with the LED tape hidden above the coving.
She has mentioned that there is going to be a mural painted onto the ceiling and would like it lit by the LED's.
Does anyone know a good LED strip. Easy to install, corner connections etc.
All I've worked on so far is the sticky backed flexible tape that can be fiddly to get straight.
Roughly 18m total length. Can this be done with only one driver, and are they available as dimmable... in case the customer asks
What would be the best way to mount the tape? On the wall, projecting horizontally into the room, and lighting up the majority of the mural, but maybe visible or on the top of the coving, shining straight up and only lighting the edge of the ceiling?
