Discuss Light issue in the UK Electrical Forum area at ElectriciansForums.net
I changed a light switch in my master bath that had 3 black wires into the switch. I kept them oriented in the same way on the new switch, but now the light in my hallway bathroom doesn’t work. Why is this ??? I haven’t changed any other wires and I have checked the breaker. House was built in 1977
does the hallwaylight work when the bathroom light is on? if so you have the wiring at the switch wrong.
the hallway light works, but the bathroom one doesn’t. The bathroom is just located off the hallway
your posts are contradictory.i post #1 you said the hall light did not work. in post 3 you say the bathroom light is not working.
9393 that looks like a 3 way switch, are you sure you bought the right switch and that possibly be your problem. Sounds to me like you need to hire an electrician because I’m sure the wires are crossed up
If you know the orientation of the wires reconnect the original and see what happens.
I don't see a ground wire connected to that green screw. Or is that optional in the USA?
Freddo if the house is very old yes they didn’t pull grounds back in the day. That light switch has 3 wires one of them is hot the other 2 probably go to the hall and bath room
So I got the hallway bathroom back on, but now the master shower doesnt work. I bought a line tester, one black is always hot the other two dead. When I turn on master bedroom light it makes another black wire hot! So the one that is always hot is going to common and the other hot one should go above the common or on the opposite side. But I did buy switch at a habitat for humanity restore, so that could also be the problem. What would the switch name be called? 3 way
[automerge]1573316556[/automerge]
There the other switch away thinking it would be a unplug and plug back in. ?‍♂️
Have you retried fitting the original switch to confirm the problem it at the new switch.
I am sure I can see grounds twisted together in the back box.
[automerge]1573317311[/automerge]
So did the original switch turn both lights on at the same time. I'm no expert with US switches but I agree with @Megawatt that looks like a 3 way switch.
Ok you got one light fixed and you say the last wire goes hot when you turn the switch on. Put that wire under the same screw opposite of the original hot wire where you have the hall light then they both will work. I’m convinced you have a 3 way switch. When you get a chance go buy a regular light switch
This was my thinking if both lights come on at the same time. The black screw should have the hot and the other two are travellers?
Reply to Light issue in the UK Electrical Forum area at ElectriciansForums.net
I bought this house a couple months ago. It was built in 1952 (same as me) but has been rewired with yellow 12 awg Romex dated 2007. Looks like a...
Hi folks, Quick query for this still practicing regarding bill payment for a job not complete. My partner recently employed an electrician to do...
