Discuss Loft conversion help? in the UK Electrical Forum area at ElectriciansForums.net
I guess the point is you can have T&E without RCD protection so long as it is not hidden < 50mm from a surface.
Feeding a CU off a 32A MCB works, but is not terribly good either as any big fault is likely to trip both the CU and the feed MCB, but again depending on what is needed that may or may not be a concern. Certainly I would be looking at a couple of RCBO in such a 2nd CU to reduce the chance of something on the sockets also taking out the lights.
But what is lacking here is the design aspect - what sort of load(s) are expected, etc. If it is just lights & sockets then a 32A feed is plenty, but if there is going to be an electric showed that suddenly looks small.
No shower the shower will be thermostatic just 8 sockets , the only thing I can think is they have a walk in wardrobe where could possible be a hair dryer and other things like tht on at the same time , but I’m thinking taking a 10mm t+e to a sub consumer unit which will be fitted close by to the existing CU and won’t be buried fit an RCD protected 2way CU one sockets for sockets one for lights ?
Why not fit the sub CU in the loft, then if it trips the recommended RCBO's in the sub board its not a trip all the way downstairs to re-set.
It’s a weird one mate would be ideal to do that but the existing CU sits on the ceiling in the hall which above that will be the middle of the bedroom upstairs so planning to fit the Sub Cu beside the existing one basically and run the circuits through the ceiling and under the new floor to where they need to go
Reply to Loft conversion help? in the UK Electrical Forum area at ElectriciansForums.net
Hi. We live in an older house and we are doing a loft conversion. We do not have an SPD on the connection to the grid and the builder's...
5K
Hi. I was asked to work on a loft conversion and a full refurbishment of a 5 bed house. The contractor said that as he is doing a loft...
Hi Everyone, Sorry for all the questions. With he help of a friend, I recently installed some insulation into my mother's loft. Whilst adding...
Hi I know I have to do more testing but I just want to see if there is something I’m missing. Customer said light fitting in the loft was...
