Discuss MCB, RCD & AFDD all in one in the UK Electrical Forum area at ElectriciansForums.net
commercial only for them ,you want be putting them in domestic ,it would be the film jaws ,we need a bigger consumer unit or bigger boat .These things are blooming huge!
These builders will have to wake up and allow bigger electrical plant rooms.No incentive to make them smaller... bigger devices = bigger boards = more money for the manufacturers
There isn’t any way to test AFDDs, without reducing their longevity or making them unserviceable.So the test button is for the RCD and not the AFDD I'm guessing.
Anybody know if there is a prescribed disconnection time that these AFDDs will have to meet?
Just wondering how they can be tested. New setting on the multifunction testers will be next I reckon £££
I've never done domesticIts all getting out of hand to be honest. Electricians are being taken for total mugs these days. Glad i dont do any domestic work anymore.
I have literally no idea what they are for
Fluke T+PRO Electrical Tester 95969327923 | eBay - https://m.ebay.co.uk/itm/Fluke-T-PRO-Electrical-Tester/192561592597?_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D52962%26meid%3D8571d8a5e7bf47c19c22ab9f028b3791%26pid%3D100675%26rk%3D1%26rkt%3D15%26sd%3D192561592597%26itm%3D192561592597&_trksid=p2481888.c100675.m4236&_trkparms=pageci%3Aad82fb35-82d4-11e8-9456-74dbd1803e5b%7Cparentrq%3A7af254541640add89ecbb937fff225ca%7Ciid%3A1These things have been around a while across the pond and it seems there is test equipment available, e.g. Greenlee AFI-100. As has already been suggested, I reckon the MFT manufacturers will waste no time jumping on the bandwagon and launch a new range of 18th ed. testers with this as new functionality.
That’s a voltage tester?Fluke T+PRO Electrical Tester 95969327923 | eBay - https://m.ebay.co.uk/itm/Fluke-T-PRO-Electrical-Tester/192561592597?_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D52962%26meid%3D8571d8a5e7bf47c19c22ab9f028b3791%26pid%3D100675%26rk%3D1%26rkt%3D15%26sd%3D192561592597%26itm%3D192561592597&_trksid=p2481888.c100675.m4236&_trkparms=pageci%3Aad82fb35-82d4-11e8-9456-74dbd1803e5b%7Cparentrq%3A7af254541640add89ecbb937fff225ca%7Ciid%3A1
Well at least fluke do a tester, so it's another one for the collection.
Will industrial electricians be exempt from fitting these things, are they only to be fitted in residential properties
I haven't been paying attention to be honest.
Yes so have some of those Martindale type socket testers.It has a built in gfci tester.
I think I must be getting confused!
I thought these AFDDs were nothing more than surge protectors?
Or is it aimed at blocks of flats too??'premises with sleeping accommodation' is a bit ambiguous, though. I'm assuming they mean hotels?
That's my take on it.'premises with sleeping accommodation' is a bit ambiguous, though. I'm assuming they mean hotels?
May also make sense since Grenfell but then you'd have thought they'd listed BMO'sOr is it aimed at blocks of flats too??
I agree. Blocks of flats are dwellings. Not sleeping accommodation.That's my take on it.
Also according to the NIC presenters, ADDS will not work on a RFC, they didn't give a very good explanation on the film they produced, but the fact that AFDDs won't work on a RFC according to them was something that stuck in my mind.Seems these things are elusive.
Eaton are quoting £160 per combined unit and a 16 day lead time.
They also do not do 3 phase units.
Ah, yes. Good point. Obvious when one gives it the merest moment of thought.Perhaps they work by detecting the gaps in the flow of current caused between arcs.
An RFC would have the gaps in current on one conductor filled in by the current flow on the other conductor.
Things can be in the regs even without a tester - after all there's never been a tester for the magnetic or thermal parts of an MCB/RCBO, only for the residual current part. Dame goes for fuses for that matter. so we have no idea if they still work when doing inspection and testing.
Yes, you can just look at the switch or at the melted fuse. But the same applies to the afdd. I thought people meant testing the device itself for correct operation, which you can only do with rcds.But if a fuse blows or an MCB trips you have test equipment to diagnose the fault quickly and reliably every time.
Yep.It is very ambiguous. The Oxford Dictionary says 'Accommodation' is "A room, group of rooms, or building in which someone may live or stay. ‘they were living in temporary accommodation’ "
Doesn't that put every house down as having "sleeping accommodation" ?
With fuses and mcbs you can only test the circuit.
With afdds not sure! Maybe neither?
Yep.
Fortunately 421.1.7 has two softeners for now. It says "If used..." and then gives "Examples of where such devices can be used...". This will change to "shall be used" at some point I guess.
Reply to MCB, RCD & AFDD all in one in the UK Electrical Forum area at ElectriciansForums.net
