Discuss MFT1552 fault? in the UK Electrical Forum area at ElectriciansForums.net
Hi all,
I was wondering if anybody has come across this fault before that I seem to be getting with my Megger MFT1552.
When I measure the voltage it reads around 260V (iv tried it in a few different properties). Then if I switch it to the RCD auto test or any of the RCD individual tests it bumps up to over 300v, flashes and doesn't let me continue. When I swotch off the socket/supply it does go do to 0 so its not registerong a voltage when there isn't one it just seems to be registering the voltages really high
I really don't want to have to call it a day with the MFT as its a great bit of kit albeit an oldey so was just wondering if anyone has come across this before?
Thanks for any info :)
Hi all,
Send the MFT away to Megger and ask them to check operation and a costing of any repairs that they uncover, if it's BER then time for a new one.
try The Calibration Centre at Stafford. They provide an excellent repair service at reasonable cost.
Try Test Meter, forum sponsor, they provide a good service.
So just an update... and I fear I may be required to hand in my electricians card as well as my man card here.... what i thought were new batteries were dead... changed the batteries and its showing correct voltage..... i mean there are no words!!!!!!
At least you admitted it, well done and a cheap fix.
Reply to MFT1552 fault? in the UK Electrical Forum area at ElectriciansForums.net
Hi there, I’m a new member to the forum and felt like I could do with some additional insight into a fault I came across on a call-out at the...
Hi all I don't appear to be able to post in the DIY forum so apologies if this is the wrong place. I live in a block of flats with an external...
Recently changed a CU for a friend and today when visiting one of the RFC's RCBOs tripped. It was due attention anyway as open ring and no time to...
I've just been to a job to replace a burned out switch where the customer supplied his own Arlec dimmer switch. During a dull moment, I read the...
Electrical2Go - Megger MFT Deals! Upgrade your toolkit with our exclusive offer! Purchase any of the Megger advanced multifunction testers –...
