Discuss Need help with wiring a celing fan in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Most of these fans come with a switch on the side to reverse the fan.
So it’s either a cooling fan, blowing down, or an air recirculating fan.
Read the instructions again.
100 percent correct. Im so glad i found this forum. Thank you all that have helped. I would recommend this forum to everyone. Im a total noob in electr9nics yet i could build a pc from a calculator and a bit of wood lol. Thank you all so much
Someone’s already done that and called it a raspberry pi
Reply to Need help with wiring a celing fan in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi, I'm looking to install a new bathroom extractor fan in my bathroom as I have a windowless bathroom and the current one I have installed in...
1964 house old style wiring Need to wire a extractor fan up Is it possible to wire the extractor fan to report switch there's 2 red wires in the...
Hello, I'm swapping my extractor fan in the UK and I have bought a Turkish extractor fan stupidly and the connections you can see in the picture...
Hi all, I'm in the UK and have recently had a ducted extractor fan Mixflo 200W with timer fitted. The fan comes on with the pull cord and runs for...
Need to replace an old Vent-Axia extractor fan as the pull chord no longer works. I bought this -...
