R
rattlehead85
Located a fault between neutral & earth on a lighting circuit consisting of pvc singles run through steel conduit run between two bedrooms. The point i don't get is the device was an RCBO which apparently has never tripped. I checked the device applying an RCD test which passed and the trip mechanism works fine. Ze value of the installation was good and also the circuit earth continuity was integral.
Any theories as to why this RCBO has not tripped under fault condition present?
