Discuss New tv point in the FreeSat, Sky, VirginMedia Forum area at ElectriciansForums.net
R
Robo
I would like to install a new tv point. The existing installation is new. Outside aeriel feeds a splitter box in the roof, and there isn't any spare ways.
Theres an existing tv point about 10m away from where I would like to install the new one. Could I tap into this face plate to feed the new?? If so can u get a tv point plate that you can connect to cables into?
Or do I have to go right back to aerial and get a larger spiller. The cable route is shocking so I'm trying to steer clear of this.
Any help appreciated
10m isn't too far. Some would consider it a little bit of a bodge but over such a short distance it won't cause you any problems daisy chaining out of the existing coax point. Dress the cables well and you can quite easily fit two coax cables into a standard coax outlet.
Top man, thanks for your help
No worries bud, that's what the 'thanks' button is for :)
you can buy points as well that have two retaining bracket, one at the top and one at the bottom
Very true, didn't really think about it as coax points I use will more often than not match the other accessories. I'm not a fan of mixing and matching but if it's only one additional point then this is another option worth exploring.
Reply to New tv point in the FreeSat, Sky, VirginMedia Forum area at ElectriciansForums.net
Hi, I live in a rural location and so the TV signal is not great. I would like some advice on what equipment I should be looking at without...
Hi fellow sparks, I've just started out on my own so I'm spending a lot of my time trying to find out the correct way of doing things of...
Been asked to move, remove and add some sockets the kitchen and I’ll need to add a circuit for an electric hob. Looked at the board and it’s one...
Hello Everyone. I'm surprised this subject does not get much attention. 'The elephant in the room' I refer to is the 'new rubber'. On new...
Hi everyone, I am new to the forum and wanting some advice regarding a tv aerial. I moved into my own flat and bought a tv, however when I...
