Discuss No earth - is it a TT looks like PME to me in the Australia area at ElectriciansForums.net
L
leolec
Just want to bounch this off others,
1980's house built in rural village, other houses in the village have PME supplies and test out with Ze of around 3.5. Did a quick test when I got there on a ring and getting Zs of 10.45 on further investigation theres no main earth so thought well is this TT if so no rod - can't be - main incomer comes out of the ground looks just like other PME supplies light grey 100A fuse box SWA going in - did the installer just miss the earth off? seems strange - 10mm Main Bonding all there.
3.5 is crap for PME anyway. could it be no earth and the reading is from the main bonding to gas and water? is there an earth terminal taken off the cut-out? have you checked in the |CU to see if there is an earth connected ( apart from the bonding)?
Thats what I've been thinking - there's no earth to the cut-out the cut-out goes straight to the meter and then to the cu, theres main bonding I didn't get time to test them but I'm assuming gas and water so my thought was I'm getting 10ohms from line to gas or water pipe
Thanks everyone,
It's an underground TT -finally found the rod, the earth cable was wrapped in condu and the rod six inches below soil level - 10ohms - great.
Don't forget when testing Ze you should have all bonding removed. 10 ohms sounds like you still had gas or water bonds attached and possibly picking up an earth from next door through this.
Better go and retest I think.
But picking up on that point then, so this house is TT with earth rod say 70 ohms and next door is say PME with 0.35 ohms, then the first house finds earth through second house rather than the rod?
Reply to No earth - is it a TT looks like PME to me in the Australia area at ElectriciansForums.net
5 single phases to one huge property. Backup generator which can take about 106 amps split between 2 phases - 1 phase will be wired through...
Evening everyone . Currently looking at pricing a job up . It’s a hot tub supply . Outside socket with a few spare ways in an outdoor cu . 10mm...
Morning guys, Just been to look at a CU change and there was a bit of an oddity with the PME connection in the old black cut out. Looking at the...
Morning guys! Went to look at a consumer unit change today with a PME supply. Now, right next to this was an old BS3036 60A fused mem cutout...
Carrying out a EICR in a commercial setting. In the main intake room the DNO supply comes in and it states clearly this is a PME system. 5 years...
