Discuss One LED out of sync in the Lighting Forum area at ElectriciansForums.net
L
Lukeswarm
Hi
I have a professionally fitted LED system but for some reason one of the LED lights is a different colour to the others (they are multi coloured led I can change)
Any ideas? Broken unit? Or something else?
How long have they been installed? Are they still under warranty?
And I also agree with Tel... :D
it's the old harmonisation issue again. the blue is now grey, so, being so, it can't work. grey is not a colour. :confused:.
As mentioned above it looks like thr blue channel or led is not wotking.
I would test all the primary colours first using the controller. Im assuming these are rgb lights? So try red on its own then green then blue. If just that bulb has just the blue led not working then try moving it to anothet bulbs place and put that bulb in that place to test if the cabling is ok. If the fault is still narrowed down to that bulb then it is faulty and would need replaceing / repairing
Osram brought it out about 10 years ago.
When you bought the house did you get any of the programming software or any other relevant information?
The light fittings may be getting controlled via dmx.
No instructions at all but I think it’s all DMX controlled as it has that written all over the controller boxes where it says DMX512 decoder
Reply to One LED out of sync in the Lighting Forum area at ElectriciansForums.net
Hi all. Slightly out of the ordinary, but I'm looking to replacing between 60 to 100 standard size E27 bulbs with LED equivalent. The catch is...
R
I am looking into LED lighting for a Grade I listed church, parts of which are 800 years old. The lighting must be simply dimmable with a colour...
Hi everyone, I would like to use LED chips for DIY projects, to power them I would start from 12V drivers for LED strips. For some chips it is...
Hi all, Great forum with lots of advice read and greatly received over the years! I have a question here that I am hopeful somebody here can...
This is the second set which won't work to replace the current spots here in my kitchen. All they do is flash once quickly. I'm replacing...
